how_to_adjust_your_valve_clearances
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| how_to_adjust_your_valve_clearances [2009/02/15 18:55] – 67.34.27.200 | how_to_adjust_your_valve_clearances [2020/10/19 11:51] (current) – external edit 127.0.0.1 | ||
| Line 19: | Line 19: | ||
| Removed Cons: adds additional time and requires more tools. | Removed Cons: adds additional time and requires more tools. | ||
| + | - Put piston at TDC(top dead center) timing reasons. | ||
| * Remove valve cover (8mm) | * Remove valve cover (8mm) | ||
| * Remove chain guard | * Remove chain guard | ||
| * Remove bridges one at a time | * Remove bridges one at a time | ||
| - | * Remove top right first, then top left, then bottom right, then bottom left | + | |
| :!: You must loosen the bolts evenly starting with the middle bolts. | :!: You must loosen the bolts evenly starting with the middle bolts. | ||
how_to_adjust_your_valve_clearances.1234745704.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
