1995_fzr600r
Table of Contents
NOTE
'95 FZR600R AKA "Foxeye" & was sold overseas. In the US, this bike was known as the YZF600.
| Year | 1995 600R | |
| Capacity | 599 | |
| Max power (rear tyre) | 99 hp @ 11500 rpm (rear tyre 90.9 hp @ 11400 rpm ) | |
| Transmission | 6 speed | |
| Front Brakes | 2x 298mm discs same as fzr600 89-93 4 piston calipers | |
| Rear Tire | 160/60 ZR17 | |
| Dry Weight | 184 kg (405.65 lbs) | |
| Standing ¼ Mile | 11.1 sec / 194.8 km/h (121.05 mph) | |
| Top Speed | 238.2 km/h (148.02 mph) | |
'95 US YZF600 MODEL 4JH wiring Diagram
'95 UK "FOXEYE" FZR600R Wiring Diagram
1995_fzr600r.txt · Last modified: 2020/10/19 11:51 by 127.0.0.1
