1994_fzr600r
| Year | 1994 600R | |
| Capacity | 599 | |
| Max power (rear tyre) | 99 hp @ 11500 rpm (rear tire 90.9 hp @ 11400 rpm) | |
| Transmission | 6 speed | |
| Front Brakes | 2x 298mm discs 4 piston calipers same as fitted to fzr600 89-on | |
| Rear Tire | 160/60 ZR17 | |
| Dry Weight | 184 kg (405.6 lbs) | |
| Standing ¼ Mile | 11.1 sec / 194.8 km/h | |
| Top Speed | 238.2 km/h (148.02 mph) | |
1994_fzr600r.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
