brake_rotors_from_other_models
There are plenty of discs about that will fit the FZR - Range 1000 & 750's WITH 320MM FRONTS, NOT REARS.
Yamaha shares this rotor:
Specs: - outer diameter: 320 mm
- inner diameter: 64 mm
- thickness: 4 mm
- offset: 9.5 mm
BOLT PATTERNS ARE THE SAME
WITH YAMAHA Models:
- FZ 1000 R from 1987 till 1989
- FZR 1000 EXUP from 1989 till 1995
· FZR 250 87-
· FZR 750 Genesis 87
· FZR 1000 Genesis 87-88
· FZR 1000 EX-UP 89-95
· SRX 400 (3VN1/3VN2/3VN5) 90-96
· SRX 600 (3SX) 90-91
· SZR 660 96-97
· TDR 250 88-92
· TZR 250 87-92
· XJR 1200 from 1994 till 1998
· XJR 1300 (5EA1) 98
· YZF 750 R/SP 93-97
- YZF 750 R from 1993 till 1995
- To make the list complete:
APRILIA:
- CAPONORD RAID from 2003
- ETV MANA from 2002
- RSV MILLE from 1998 till 2000
- RSV MILLE R 2000
- RSV MILLE SP 2000
- SL 1000 FALCO 2000
DUCATI:
- 620ie MONSTER from 2001
- 620 SS from 2003
- 748 DESMOQUATTRO from 1994 till 1997
- 748 E/S & R from 1998 till 2002
- 749 also S from 2003
- 750 SS from 1991 till 1998
- 800 SS from 2003
- 800 SPORT from 2003
- 851 from 1988 till 1991
- MH 900 E 2000
- 900 M MOSTRO from 1993 till 2000
- 900 SS from 1991 till 1998
- MOSTRO S4 from 2001 till 2002
- 916 all models from 1994 till 1998
- 996 from 1999 till 2001
- 1000 MOSTRO from 2003
the FZR600 uses 298mm diameter discs 64mm inner diameter 4mm thick minimum thickness is 3.5mm the discs are fitted to FZR600 1989-93 FZR600R 1994-95 after this date the discs are 320mm (yzf600r) as fitted to the fs6 and R6 etc
I Hope it helps someone struggling to find replacements!!!!!!!
- Ozzyfzr
Thanks Guy well done Y-G
brake_rotors_from_other_models.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
