how_to_adjust_your_valve_clearances
FIXME
  • Difficulity: medium
  • Attention to detail: medium
Once you have recorded the clearances and the shim sizes you want to use the shimulator to calculate your new shims. Shimulator
  1. Put piston at TDC(top dead center) timing reasons.
  • Remove valve cover (8mm)
  • Remove chain guard
how_to_adjust_your_valve_clearances.txt · Last modified: 2020/10/19 11:51 by 127.0.0.1
