1994_fzr600r
Year1994 600R
Capacity599
Bore x Stroke62 x 49.6 mm
Max power (rear tyre)99 hp @ 11500 rpm (rear tire 90.9 hp @ 11400 rpm)
Transmission6 speed
Front Tire120/60 ZR17
Rear Tire160/60 ZR17
Dry Weight184 kg
Standing ¼ Mile11.1 sec / 194.8 km/h
Top Speed238.2 km/h
1994_fzr600r.1211437272.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
