1994_fzr400_rr_sp
Year1994RR-SP
Capacity399
Bore x Stroke56×40.5mm
Compression Ratio12.2:1
Induction4x 32mm 4x 32mm Keihin FCR Carburetors
IgnitionElectronic digital control
Max Torque4 kg-m @ 9500 rpm
Front Suspension43mm forks with adjustable preload, rebound and compression damping
Front Tire120/60-17
Rear Tire160/60-17
Dry Weight160 kg
Fuel Capacity15 Litres
Consumption average41.3 mp/g
Top Speed110.5 mp/h
1994_fzr400_rr_sp.1281763311.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
