1990_fzr250r
Year1990
Capacity249
Bore x Stroke48×34.5mm
Compression Ratio12:1
Induction4x Mikuni carbs
IgnitionCDI
Max power (rear tyre)45hp @16,000rpm
Max Torque2.5kg-m@12,000rpm
Front Suspension38mm Telescopic forks
Rear SuspensionMonoshock preload adjustable
Front Brakes2x 285mm discs 4 piston calipers
Front Tire100/80-17
Rear Tire130/70-17
Dry Weight146kg
Fuel Capacity14 Litres
Standing ¼ MileNot Available
Top SpeedNot Available
1990_fzr250r.1211436800.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
