1990_fzr250r
| Year | 1990 | |
| Capacity | 249 | |
| Bore x Stroke | 48×34.5mm | |
| Compression Ratio | 12:1 | |
| Induction | 4x Mikuni carbs | |
| Ignition | CDI | |
| Max power (rear tyre) | 45hp @16,000rpm | |
| Max Torque | 2.5kg-m@12,000rpm | |
| Front Suspension | 38mm Telescopic forks | |
| Rear Suspension | Monoshock preload adjustable | |
| Front Brakes | 2x 285mm discs 4 piston calipers | |
| Front Tire | 100/80-17 | |
| Rear Tire | 130/70-17 | |
| Dry Weight | 146kg | |
| Fuel Capacity | 14 Litres | |
1990_fzr250r.1211344664.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
