1989_fzr400
Year1989
EngineLiquid cooled, four stroke, transverse four cylinder, DOHC, 4 per cylinder.
Capacity399
Bore x Stroke56 x 40.5 mm
Compression Ratio11.5:1
ClutchWet multiple plates
Ignition
Max Torque3.9 kg-m @ 9500 rpm
Transmission6 Speed / chain
Front Suspension41mm Telescopic forks
Rear SuspensionMonoshock single shock preload adjustable.
Front Brakes2x 298mm discs 2 piston calipers
Front Tire110/70R-17
Rear Tire140/60R-18
Dry Weight155 kg
Fuel Capacity15 Litres
Consumption average
Braking 60 - 0 / 100 - 0
Standing ¼ Mile13.1 sec / 101 mp/h
Top Speed122 mp/h
1989_fzr400.1263735492.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
