1988_fzr250
| Year | 1988 | |
| Capacity | 249 | |
| Bore x Stroke | 48×34.5 | |
| Compression Ratio | Not Available | |
| Ignition | CDI | |
| Max power (rear tyre) | 45hp@14,500rpm | |
| Max Torque | 2kg-m@11,500rpm | |
| Front Suspension | Not Available | |
| Rear Suspension | Not Available | |
| Front Brakes | Single disc/Twin disc after delta box frame | |
| Rear Brakes | Single disc | |
| Front Tire | 100/80-17 | |
| Rear Tire | 120/80-17 | |
| Dry Weight | 141kg | |
1988_fzr250.1261022660.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
