1993_fzr600
Year1993
Capacity599
Bore x Stroke59 x 54.8 mm
Induction4x 32mm Mikuni BDST32
Max power (rear tyre)91 hp 606.3 kW @ 10500 rpm
Max Torque65.7 Nm @ 8500 rpm
Front Tire110/70-17
Rear Tire140/60-18
Dry Weight181 kg (399.03 lbs)
Fuel Capacity18 Litres
Consumption average18.7 km/lit
Braking 60 - 0 / 100 - 013.3 m / 36.88m
Standing ¼ Mile11.4 sec / 189.0 km/h (117.44 mph)
Top Speed237.1 km/h (147.33 mph)
1993_fzr600.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
