1986_fzr250
Year1986
Capacity249cc
Bore x Stroke48×34.6mm
Compression RatioNot Available
InductionNot Available
IgnitionCDI
Max power (rear tyre)45hp@14,500rpm
Max Torque2kg-m @11,500rpm
Front SuspensionNot Available
Rear SuspensionNot Available
Front Brakes2x discs
Rear BrakesSingle disc
Front Tire100/80-17
Rear Tire120/80-17
Dry Weight141kg
Fuel CapacityNot Available
Standing ¼ MileNot Available
Top SpeedNot Available
—- Sourced:http://www.motorcyclespecs.co.za
1986_fzr250.1211436588.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
