1991-92_fzr600
Year91-92
EngineLiquid cooled, four stroke, transverse four cylinder, DOHC, 4 valves per cylinder.
Capacity599cc
Bore x Stroke59 x 54.8 mm
Induction4x 32mm Mikuni BDST32
IgnitionTransistor controlled digital / electric
Max power (rear tire)91 hp 66.3 kW @ 10500 rpm
Max Torque65.7 Nm @ 8500 rpm
Front Tire110/70-17
Rear Tire140/60-18
Dry Weight181 kg
Fuel Capacity18 Liters = 4.7551 Gallons (US)
Consumption average18.7 km/lit
Braking 60 - 0 / 100 - 013.3 m / 36.88m
Standing ¼ Mile11.4 sec / 189.0 km/h
Top Speed237.1 km/h
1991-92_fzr600.1211097464.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
