1986_fzr400
| Year | 1986 | |
| Capacity | 399 | |
| Bore x Stroke | 54×43.6mm | |
| Compression Ratio | 11.5:1 | |
| Max power (rear tyre) | 59hp @12,000rpm (Rear tire 50hp @11,500rpm) | |
| Max Torque | 3.7kg-m @10000rpm | |
| Transmission | 6 speed | |
| Front Suspension | Not Available | |
| Rear Suspension | Not Available | |
| Front Brakes | 2x Discs | |
| Rear Brakes | Single disc | |
| Front Tire | 100/90-16 | |
| Rear Tire | 120/80-18 | |
| Dry Weight/Wet Weight | 166kg/185kg | |
| Consumption average | 21.6km/lit | |
| Braking 60 - 0 / 100 - 0 | 14.0m/42.3m | |
| Standing ¼ Mile | 12.9sec/162 km/h | |
| Top Speed | 197.5 km/h | |
1986_fzr400.1211436832.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
