1986_fzr400
Year1986
Capacity399
Bore x Stroke54×43.6mm
Compression Ratio11.5:1
InductionNot Available
IgnitionNot Available
Max power (rear tyre)59hp @12,000rpm (Rear tire 50hp @11,500rpm)
Max Torque3.7kg-m @10000rpm
Transmission6 speed
Front SuspensionNot Available
Rear SuspensionNot Available
Front Brakes2x Discs
Rear BrakesSingle disc
Front Tire100/90-16
Rear Tire120/80-18
Dry Weight/Wet Weight166kg/185kg
Fuel CapacityNot Available
Consumption average21.6km/lit
Braking 60 - 0 / 100 - 014.0m/42.3m
Standing ¼ Mile
Top Speed197.5 km/h
1986_fzr400.1211345291.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
