remove_the_flywheel
How to Remove the Flywheel
Time: 30 minutues
Required Tools:
- 5mm allen wrench
- Hammer
- Socket wrench
Directions:
- Use the 5mm allen tool to remove the stator cover (left side of bike)
- Remove the bolt in the middle of the flywheel (you may need a breaker bar)
- Screw in the flywheel puller (tighten to around 20 Nm or so, as long as its not loose)
- Take a hammer and whack the flywheel puller (Careful, don't damage the flywheel)
- It may take a few whacks for the flywheel to loosen, it should then just slide right off
- After removing the flywheel there should be a flywheel key (a little half moon shaped bit of metal ) that holds it in place, don't lose this.
remove_the_flywheel.txt · Last modified: 2020/10/19 11:51 by 127.0.0.1
