1989-90_fzr600
| Year | 89-90 | |
| Capacity | 599cc | |
| Induction | 4x 38mm Mikuni BDST32 | |
| Front Tire | 110/70-17 | |
| Rear Tire | 130/70-18 | |
| Dry Weight | 179 kg (394.6 lbs) | |
| Consumption average | 43 mp/g | |
| Braking 60 - 0 / 100 - 0 | 13.19 / 37.82 m | |
| Standing ¼ Mile | 11.5 sec / 186.8 km/h (116.08 mph) | |
| Top Speed | 234.4 km/h (145.66 mph) | |
PAINT SCHEME FOR US YEARS ONLY
1989-90_fzr600.1289211829.txt.gz · Last modified: 2020/10/19 11:48 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
