1990_fzr_1000_exup
| Year | 1990 FZR1000 (EXUP) | |
| Engine | Four Cylinder, Four Stroke, DOHC, Five Valve, Liquid cooled, 35° forward inclined transverse mounted | |
| Capacity | 1002cc / 61.1 cubic inches | |
| Compression Ratio | 12.0 : 1 | |
| Fueling | (4) 38mm Mikuni BDST Constant Velocity Carburetors | |
| Ignition / Starting | Digital / Electric | |
| Maximum Power @ Crankshaft | 105.7 kW / 141.7 hp @ 10000 rpm | |
| Maximum Torque | 10.9 kg-m / 107 N-m / 77.4 ft-lbs @ 8500 rpm | |
| Transmission | 5 Speed Manual / Wet Multi-Plate Hydraulic Clutch / Chain Final Drive | |
| Front Suspension | 43mm Diameter Telehydraulic Forks, Adjustable Peload, 120mm Travel | |
| Rear Suspension | Gas/Oil Single Shock, Rising Rate Linkage, Adjustable Preload & Rebound Damping, 130mm Travel | |
| Front Brakes | Twin 320mm Diameter Discs w/4 Piston Hydraulic Calipers | |
| Rear Brake | Single 267mm Diameter Disc w/2 Piston Hydraulic Caliper | |
| Front Wheel / Tire | 3.5“ x 17” / 130/60 VR17 | |
| Rear Wheel / Tire | 5.5“ x 17” / 170/60 VR17 | |
| Dry Weight | 209kg / 461 lbs | |
| Wet Weight | 236kg / 520 lbs | |
| Fuel Capacity | 19 Litres / 5.1 US Gallons | |
| Consumption average | 16.3 km/litres / 38.3 mpg US | |
| Braking 60 - 0 | 13.1 meters / 43 feet | |
| Braking 100 - 0 | 37.0 meters / 121 feet | |
| Standing ¼ Mile | 10.1 sec @ 216.8 kph / 134.7 mph | |
| Top Speed | 273.4 kph / 170mph | |
1990_fzr_1000_exup.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
