r6_99-02_r6_fork_swap
http://fzrsupport.com/forum/viewtopic.php?f=30&t=2561
  • By using a threaded rod in 1/2inch or 5/8inch you are able to use any
year model or make for this build. My first set of bushings were single sided and r6 stem was chopped to use for taking up the slack in the upper and lower triple holes.
  • We now have come up with a design to use a double ended bushing on the top
and bottom of the triple and bearings. It will serve as taking up slack in the triples and providing a place for the bearings to rest on. Oem bearings are retained in this mod.
  • The 1st set of bushings were made from 6061 Aluminum Rod. These are still in place
and used in my bike. I will give a 500 mile and 1000 mile inspection this summer. We have now changed to Steel Double Sided bushings giving it a more solid fit for added security and tolerances.
  • I want to thank (Rob) CAD600 for everything on this build. Together we will be
able to provide the bushings for any fork build you may have.
  • I have purchased my own metal lathe and will be producing bushings for this mod.
If you need anything made let one of us know. Thanks!8-)
Materials List:
  • Triples, these are for a 99-02 R6 but any other YEARS / MODEL will work
  • Fork Tubes, that match the Triples
  • Clipons, that match the forks
  • Wheel / Brakes, that match the forks
  • Use your existing FZR bearings,spacers and dust caps
  • In the future we will be using a double ended bushing for top and bottom and the OEM stem will not be used.
UPDATE from TONY FOALE on the Design
see:-http://fzrsupport.com/forum/viewtopic.php?f=30&t=2561&start=105
OR
Pix entitled “BottomYoke., Bottom Yoke 1, Bottom yoke 2, Bottom yoke 3…” at
http://www.tonyfoale.com/AermacchiFrame/?N=A
Editted by Y-G on 2010-01-05
r6_99-02_r6_fork_swap.txt · Last modified: 2023/07/05 13:46 by 192.168.1.1
