* FZR 600 {3HE} front rotors = 7.26 lbs
  • FZR 400 {3tj} rear wheel (17 * 4.5“) with cush drive , sprocket carrier and disc only) 8.38Kg = 18.474 lbs
  • FZR 400 {1WG} swing arm with rear axle 3.1KG = 6.834 lbs
  • FZR 400 {3EN} reinforced as stock with axle 7.4 Kg = 16.314 lbs
  • 97-00 GSXR600 SRAD swingarm weighs 5.4kg or 11.88lbs
  • '03 GSXR 600 rear wheel 5.5”X17 with a dunlop tire,cush,sprocket & rotor wieghs 14.8kg or 32.5lbs
  • SV 650 Without rotor and sprocket rear wheel is 16lbs.
  • SV 650 Front wheel without rotors is 9.2lbs.
  • FZR400 IWG Stock subframe with undertray, tail light, no battery box, and foot pegs is 8.4kg or 18.5lbs
  • Fox Twin Clicker Rear shock 3.6kg or 7.92 lbs
  • FZR 600 stock Rear shock 2.52 kg or 5.54 lbs
  • FZR 400 huge battery weighs 4.4kg or 9.7lbs
fzr_other_models_parts_weights.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
