fairing_repairs_with_plastex
In this case, the lower right hand fairing had a missing piece where the front wheel hit it due to the previous owner using a curb like a ramp. I wanted to keep my graphics, so I started looking for a donor piece, which I got from a fellow enthusiast. I had to use some of the extra plastic to fill the gap, as measurements were a little off, after cutting the pieces to fit, I took a razor blade and cut the edges of the piece so that when placed into my fairing there is a V along the crack. I held the pieces together with scotch tape.
FrontBack
Putting on the Plastex™ epoxy
This stuff goes on really easily, and it's strong as hell, I think this is pretty amazing stuff . Plaztex™ rules! The first piece I Plastex'd together I put a bunch of pressure on and it didn't break, if I have enough left after fixing all the major cracks I'm going to use the fiberglas that came with the kit to reinforce the big chunk that was missing. It's really strong, it actually turns into plastic and seems to flex fairly well, it's as strong or stronger than the stock plastic.
-Dr. Rockso
fairing_repairs_with_plastex.1212262263.txt.gz · Last modified: 2020/10/19 11:47 (external edit) · Currently locked by: 216.73.216.175,10.8.253.253
