fairing_repairs_with_plastex
FrontBack
Putting on the Plastex™ epoxy
This stuff goes on really easily, and it's strong as hell, I think this is pretty amazing stuff . Plaztex™ rules! The first piece I Plastex'd together I put a bunch of pressure on and it didn't break, if I have enough left after fixing all the major cracks I'm going to use the fiberglass that came with the kit to reinforce the big chunk that was missing. It's really strong, it actually turns into plastic and seems to flex fairly well, it's as strong or stronger than the stock plastic.
-Dr. Rockso
fairing_repairs_with_plastex.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
