Parts List
  • Electrosport Speedsensor S4
  • Electrosport Wiring Kit
Wiring to the Stock Harness
Nine Pin Connector Layout
[Top Notch]
Six Pin Connector Layout
[Top Notch ]
Blank Blank Blank
Red(2X) : A&B PowerLeads Black(2x) : A&B GND Yellow : Tachometer
The Tachometer wire that Acewell/Electrosport supplies with the kit is extremely long for those that wish to coil it around an ignition coil. Since I intended to tap the wire into the stock harness I snipped the excess, and using a male female spade connector; I used the excess wire to run the Brown Clock Power Wire through the frame to the positive terminal on the battery (1/4 inch 22 gauge spade at the terminal). In the picture above you will see the brown wire joined to a yellow wire by way of a red spade connection.
The Speedometer Sensor is fairly simple to connect as it completely replaces the old speedometer and interfaces directly into the Acewell/Electrosport harness.
The Water Temperature sensor is a stand-alone unit that also interfaces directly into the Acewell/Electrosport unit. After discussing the stock configuration the Acewell/Electrosport Technician advised against splicing into the stock sensor and schematic. FIXME I have yet to determine where in the coolent lines I will mount their secondary temperature sensor FIXME The Plus side to this is the sensor that trigger the electric fan remains untouched and will still function as normal. The downside is somewhere you will have to hack into your coolant line to interface their sensor.
-ShogunTX (Inspiration by MsHap visit her site Jello's Homepage)
electrosport_gauges_digital_upgrade.1222050836.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
