1993_fzr_1000_exup
| Year | 1993 FZR1000 (EXUP) | |
| Capacity | 1002 | |
| Induction | 4x 38mm Mikuni | |
| Ignition / Starting | ||
| Max power (rear tire) | 145 hp 105.7 kW @ 10000 rpm (rear tyre 133.4 hp @ 10000 rpm ) | |
| Max Torque | 10 kg-m. 98.1Nm @ 8500 rpm | |
| Transmission / Drive | 5 Speed / Chain | |
| Front Suspension | 41mm Upside-down forks, preload adjustable. | |
| Rear Suspension | Monocross preload, compression and rebound damping adjustable. | |
| Front Brakes | 2x 310mm discs 6 piston calipers | |
| Rear Brakes | Single 240mm disc 2 piston caliper | |
| Rear Tire | 170/60 VR | |
| Dry-Weight / Wet-Weight | 214kg (471.8 lbs) / 231 kg (509.7 lbs) | |
| Consumption average | 17.1 km/lit | |
| Braking 60 - 0 / 100 - 0 | 12.3 m / 34.5 m | |
| Standing ¼ Mile | 10.1 sec / 216.5 km/h (134.53 mph) | |
| Top Speed | 273.1 km/h (169.70 mph) | |
1993_fzr_1000_exup.1243035589.txt.gz · Last modified: 2020/10/19 11:46 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
