1989_fzr400r
Year1989
EngineLiquid cooled, four stroke, transverse four cylinder, DOHC, 4 per cylinder
Capacity399
Bore x Stroke56×40.5mm
Compression Ratio11.5:1
InductionNot Available
IgnitionNot Available
Max power (rear tyre)59hp@ 12,000rpm
Max Torque3.9kg-m @9,500rpm
Transmission6 speed
Front Suspension41mm Telescopic forks
Rear SuspensionMonoshock single shock preload adjustable
Front Brakes2x 298mm discs 1 piston caliper
Front Tire110/70-17
Rear Tire140/60-18
Dry Weight165kg
Fuel CapacityNot Available
Standing ¼ MileNot Available
Top SpeedNot Available
1989_fzr400r.1217212304.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
