1989-90_fzr600
Year89-90
EngineLiquid cooled, four stroke, transverse four cylinder, DOHC, 4 valves per cylinder.
Capacity599cc
Bore x Stroke59 x 54.8 mm
Induction4x 38mm Mikuni BDST32
IgnitionTransistor controlled digital / electric
Max power (rear tire)91 hp 66.3 kW @ 10500 rpm
Max Torque65.7 Nm @ 8500 rpm
Front Brakes2x 298mm discs 2 piston calipers
Front Tire110/70-17
Rear Tire130/70-18
Dry Weight179 kg (394.6 lbs)
Fuel Capacity18 Liters = 4.7551 Gallons (US)
Consumption average43 mp/g
Braking 60 - 0 / 100 - 013.19 / 37.82 m
Standing ¼ Mile11.5 sec / 186.8 km/h (116.08 mph)
Top Speed234.4 km/h (145.66 mph)
PAINT SCHEME FOR US YEARS ONLY
* Your countries year list may vary !!!
USA Model 1990 bike in white
1989-90_fzr600.1289211870.txt.gz · Last modified: 2020/10/19 11:46 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
