fairing_repairs_with_plastex
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| fairing_repairs_with_plastex [2008/05/31 14:45] – 70.255.83.192 | fairing_repairs_with_plastex [2020/10/19 11:50] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| - | In this case, the lower right hand fairing had a missing piece where the front wheel hit it due to the previous owner using a curb like a ramp. I wanted to keep my graphics, so I started looking for a donor piece, which I got from a fellow enthusiast. I had to use some of the extra plastic to fill the gap, as measurements were a little off, after cutting the pieces to fit, I took a razor blade and cut the edges of the piece so that when placed into my fairing there is a V along the crack. I held the pieces together with scotch | + | In this case, the lower right hand fairing had a missing piece where the front wheel hit it due to the previous owner using a curb like a ramp. I wanted to keep my graphics, so I started looking for a donor piece, which I got from a fellow enthusiast. I had to use some of the extra plastic to fill the gap, as measurements were a little off, after cutting the pieces to fit, I took a razor blade and cut the edges of the piece so that when placed into my fairing there is a V along the crack. I held the pieces together with Scotch(r) |
| :!:This stuff will mess with paint & stickers, if you use alot of the plastex liquid , or if you let it run everywhere and don't wipe it up.:!: | :!:This stuff will mess with paint & stickers, if you use alot of the plastex liquid , or if you let it run everywhere and don't wipe it up.:!: | ||
| Line 27: | Line 27: | ||
| This stuff goes on really easily, and it's strong as hell, I think this is pretty amazing stuff . Plaztex(tm) rules! | This stuff goes on really easily, and it's strong as hell, I think this is pretty amazing stuff . Plaztex(tm) rules! | ||
| - | The first piece I Plastex' | + | The first piece I Plastex' |
| + | [[http:// | ||
| -Dr. Rockso | -Dr. Rockso | ||
fairing_repairs_with_plastex.1212263135.txt.gz · Last modified: 2020/10/19 11:47 (external edit) · Currently locked by: 216.73.216.175,10.8.253.253
