remove_the_flywheel
How to Remove the Flywheel
- Time: 30 minutues
- Required Tools: 5mm allen, flywheel puller, hammer, socket wrench
Directions
- Use the 5mm allen tool to remove the stator cover (left side of bike)
- Remove the bolt in the middle of the flywheel (you may need a breaker bar)
- Screw in the flywheel puller (tighten to around 20 Nm or so, as long as its not loose)
- Take a hammer and whack the flywheel puller (Careful, don't damage the flywheel)
- It may take a few whacks for the flywheel to loosen, it should then just slide right off
- After removing the flywheel there should be a flywheel tab that holds it in place, don't loose this.
remove_the_flywheel.1212470957.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
