r6_99-02_r6_swingarm_swap
99-02 R6 SWING ARM SWAP
http://fzronline.com/forum/viewtopic.php?f=30&t=1173
  • In this swap I removed the OEM swing arm and installed the R6 swing arm.
  • In order to get the R6 swinger in there I had to remove quite a bit of metal
a small bolt to keep it from backing out. That was MSZILVES idea from his YZF600 swing arm swap. Thanks Mark!
  • I had to fab up a new upper shock mount to fit the R6 shock. Once mounted I then
had to purchase a set of triangle lowering links because the rear end sat up to high and when the kick stand was down it wanted to tip over. I have seen now they are selling the turnbuckle style which makes for an easier lowering and no tire removal.
Materials List
  • R6 Swing Arm
  • Rear caliper
  • Master Cylinder
  • Rotor
  • Hub w/bolts
  • Axle w/spacers
  • Rim and tire 180/55/17
  • Shock w/fab mount
  • 520 Rear Sprocket
  • 520 Chain w/120 link
  • Chain Adjusters
  • Swingarm w/shock
  • Entire Assembly
  • Old Assembly
  • FZR Swinger Removal
  • FZR Front Sprocket
  • Me grinding away
  • Cut off heal guard bracket
  • Pivot bolt hole
  • Rear view
  • Pivot bolt bushing
  • Difference I had to cut
  • Checking for clearance
  • YAY it fits
  • Closer view
  • Fabbed up upper shock mount
r6_99-02_r6_swingarm_swap.txt · Last modified: 2020/10/19 11:51 by 127.0.0.1
