clutch-page
You may wish to refer to the clutch drawing at:- paper writing http://www.yamaha-motor.com/sport/parts/home.aspx
Clutch slipping
- The manual says:
  • Incorrect clutch adjustment
  • Weak clutch springs
  • Worn clutch plates
  • Damaged pressure plate
Changing Clutch Plates
Removal
2. Drain the oil.
6. Remove the pressure plate.
13. Remove the clutch boss.
Inspection
Installation
7. Install the clutch boss.
9. Install the clutch nut.
22. Refill the engine oil.
23. Adjust the clutch.
24. Install the fairings.
WIKI-ized by Y-G
added to the WIKI 2009-02-02
WiKi-ized by Y-G
added to the WIKI 2009-06-18
You're done!
clutch-page.1263041599.txt.gz · Last modified: 2020/10/19 11:49 (external edit) · Currently locked by: 216.73.216.175,10.8.253.253
