1994_fzr600r
Year1994 600R
Capacity599
Bore x Stroke62 x 49.6 mm
Max power (rear tyre)99 hp @ 11500 rpm (rear tire 90.9 hp @ 11400 rpm)
Transmission6 speed
Front Brakes2x 298mm discs 4 piston calipers same as fitted to fzr600 89-on
Front Tire120/60 ZR17
Rear Tire160/60 ZR17
Dry Weight184 kg (405.6 lbs)
Standing ¼ Mile11.1 sec / 194.8 km/h
Top Speed238.2 km/h (148.02 mph)
1994_fzr600r.1280436558.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
