1994_fzr400_rr_sp
| Year | 1994 | |
| Capacity | 399 | |
| Ignition | Electronic digital control | |
| Front Suspension | 43mm Upside-down forks with adjustable preload, rebound and compression damping | |
| Front Tire | 120/60-17 | |
| Rear Tire | 160/60-17 | |
| Dry Weight | 160 kg | |
| Top Speed | 110.5 mp/h | |
1994_fzr400_rr_sp.1211348529.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
