1990_fzr400_rr_and_sp
Year1990RR
Capacity399
Bore x Stroke56×40.5mm
Compression Ratio12.2:1
Induction4x32mm Mikuni carbs
IgnitionNot Available
Max power (rear tyre)60 hp @ 12500 rpm
Max Torque4 kg-m @ 9500 rpm
Front Suspension43mm telescopic forks
Rear SuspensionMonoshock single shock preload adjustable
Rear BrakesSingle 210mm disc 2 piston calipers
Front Tire120/60 VR17
Rear Tire160/60 VR17
Dry Weight160kg
Fuel Capacity15 Liters
Consumption average36 mp/g
Standing ¼ Mile13.1sec/101mp/h
Top Speed122mp/h
Year1990RR-SP
Capacity399
Induction4x 32mm Mikuni CV
IgnitionElectonic Digital Control
Front Suspension43mm forks with adjustable preload, rebound and compression damping
Front Tire120/60-17
Rear Tire160/60-17
Dry Weight160 kg
Fuel Capacity15 liters
Consumption average41.3 mp/g
Standing ¼ Mile13.6 sec/100.5 mp/h
Top Speed110.5 mp/h
Sourced:http://www.motorcyclespecs.co.za http://www.rampant-racing.com/fzr400models.html#FZR400%20Model%20Differences
1990_fzr400_rr_and_sp.1281763838.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
