1991-92_fzr_1000_exup
| Year | 1991-92 FZR1000 (EXUP) | Engine | Liquid cooled, four stroke, 35° forward inclined transverse four cylinder, DOHC, 5 valves per cylinder. | Capacity | 1002 | Bore x Stroke | 75.5 x 56 mm | Compression Ratio | 12.0:1 | Induction | 4x 38mm Mikuni BDST | Ignition / Starting | Digital / electric | Max power (rear tire) | 145 hp 105.7 kW @ 10000 rpm (rear tyre 131.7 hp @ 10500 rpm) | Max Torque | 10.9 kg-m 107 Nm @ 8500 rpm | Transmission / Drive | 5 Speed / chain | Front Suspension | 43mm Telehydraulic for adjustable preload, 120mm wheel travel. | Rear Suspension | Gas/oil single shock, rising rate adjustable preload and damping. 130mm wheel travel. | Front Brakes | 2x 320mm discs 4 piston calipers | Rear Brakes | Single 267mm disc 1 piston caliper | Front Tire | 130/60 VR17 | Rear Tire | 170/60 VR17 | Dry Weight / Wet-Weight | 209 kg / 236 kg | Fuel Capacity | 19 Litres | Consumption average | 16.3 km/litres | Braking 60 - 0 / 100 - 0 | 13.1 m / 37.0m | Standing ¼ Mile | 10.1 sec / 216.8 km/h | Top Speed | 290 km/h | |||||||||||||||||||||||||||||||||||||||||||
WIRING DIAGRAM FZR1000 '91 UK model
info about the 1992 fzr 1000 swingarm and wheel.
- A) width of the inside of the swingarm where the wheel's axle gets in is 267 mm.
- B) width of the wheel with sproket carier on, from bearing to bearing is 210 mm.
C) each side wheel spacer's width is 13 mm. D) caliper bracket's width is 27-28 mm. E) A)+B)+C)+D) = 264 mm. F) A)- E) = 3mm (calculated error by Yamaha so you can slide the whole wheel assembly in)
Supplied by TrifGeorge
1991-92_fzr_1000_exup.txt · Last modified: 2020/10/19 11:51 by 127.0.0.1
