1989_fzr_1000_exup
| Year | 1989 FZR1000 (EXUP) | |
| Engine | Liquid cooled, four stroke, 35° forward inclined transverse four cylinder, DOHC, 5 valves per cylinder, EXUP exhaust control system | |
| Capacity | 1002 | |
| Induction | 4x 38mm Mikuni BDST | |
| Ignition | Digital / electric | |
| Max power (rear tire) | 145 hp 105.7 kW @ 10000 rpm (rear tyre 131.7 hp @ 10500 rpm) | |
| Max Torque | 10.9 kg-m 107 Nm @ 8500 rpm | |
| Transmission | 5 Speed / chain | |
| Front Suspension | 43mm Telehydraulic for adjustable preload, 120mm wheel travel. | |
| Rear Suspension | Gas/oil single shock, rising rate adjustable preload and damping. 130mm wheel travel. | |
| Front Brakes | 2x 320mm discs 4 piston calipers | |
| Rear Brakes | Single 267mm disc 1 piston caliper | |
| Rear Tire | 170/60 VR17 | |
| Dry Weight | 209 kg / 236 kg | |
| Consumption average | 19 Litres | |
| Braking 60 - 0 / 100 - 0 | 13.1 m / 37.0m | |
| Standing ¼ Mile | 10.1 sec / 216.8 km/h | |
| Top Speed | 273.4 km/h | |
1989_fzr_1000_exup.1212194987.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
