1989_fzr750r_owo1
Year1989 FZR750R (OWO1)
Capacity749
Bore x Stroke72 x 46 mm
Compression Ratio11.2:1
Induction4X 38mm Mikuni carbs
Ignition / StartingElectronic triggered / Electric
Max power (rear tire)121 hp 88.3 KW @ 12000- (rear tyre 108.8 hp @ 12500 rpm )
Max Torque7.2 kg-m @ 9000 rpm
Transmission / Drive6 Speed / Chain
Front Suspension43mm Telescopic preload forks, compression and rebound damping adjustment.
Rear SuspensionÖhlins Monocross preload compression and rebound damping adjustment.
Front Brakes2x 280mm discs 4 piston calipers
Rear BrakesSingle 177mm disc 2 piston caliper
Front Tire120/70-ZR17
Rear Tire170/60-ZR17
Dry-Weight222 kg (489.42 lbs)
Fuel Capacity22 Litres
Consumption average16.2 km/lit
Braking 60 - 0 / 100 - 012.7 m / 35.3 m
Standing ¼ Mile10.7 sec / 205.8 km/h (127.88 mph)
Top Speed257.8 km/h (160.20 mph)
1989_fzr750r_owo1.1243035150.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
