1989_fzr750r_owo1
| Year | 1989 FZR750R (OWO1) | |
| Capacity | 749 | |
| Bore x Stroke | 72 x 46 mm | |
| Compression Ratio | 11.2:1 | |
| Induction | 4X 38mm Mikuni carbs | |
| Ignition / Starting | Electronic triggered / Electric | |
| Max power (rear tire) | 121 hp 88.3 KW @ 12000- (rear tyre 108.8 hp @ 12500 rpm ) | |
| Max Torque | 7.2 kg-m @ 9000 rpm | |
| Transmission / Drive | 6 Speed / Chain | |
| Front Suspension | 43mm Telescopic preload forks, compression and rebound damping adjustment. | |
| Rear Suspension | Öhlins Monocross preload compression and rebound damping adjustment. | |
| Front Brakes | 2x 320mm discs 4 piston calipers | |
| Rear Brakes | Single 177mm disc 2 piston caliper | |
| Front Tire | 120/70-ZR17 | |
| Rear Tire | 170/60-ZR17 | |
| Wet-Weight | 222 kg (489.42 lbs) | |
| Fuel Capacity | 22 Litres | |
| Consumption average | 16.2 km/lit | |
| Braking 60 - 0 / 100 - 0 | 12.7 m / 35.3 m | |
| Standing ¼ Mile | 10.7 sec / 205.8 km/h (127.88 mph) | |
| Top Speed | 257.8 km/h (160.20 mph) | |
1989_fzr750r_owo1.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
