1988_fzr750_genesis
| Year | 1988 FZR750 (GENESIS) | |
| Capacity | 749 | |
| Bore x Stroke | 68 x 51.6 mm | |
| Compression Ratio | 11.2:1 | |
| Induction | 4x 34mm Mikuni carb | |
| Ignition / Starting | Electronic triggered / Electric | |
| Max power (rear tire) | 106 hp 77.4 KW @ 10500 rpm ( 92.5 hp @ 10500 rpm ) | |
| Max Torque | 7.2 kg-m @ 8250 rpm | |
| Transmission / Drive | 6 Speed / chain | |
| Front Suspension | 41mm Kayaba forks 130mm wheel travel adjustable for spring preload and rebound damping. | |
| Rear Suspension | Monoshock single Kayaba damper 30mm wheel travel adjustable for spring preload and rebound damping. | |
| Front Brakes | 2x 320mm disc 2 piston caliper | |
| Rear Brakes | Single 267mm disc 2 piston caliper | |
| Front Tire | 120/70 VR17 | |
| Rear Tire | 160/60 VR18 | |
| Dry-Weight / Wet-Weight | 213 kg / 235 kg | |
| Fuel Capacity | 20 Litres | |
| Consumption average | 18 km/lit | |
| Braking 60 - 0 / 100 - 0 | 13.5 m / 38.9 m | |
| Standing ¼ Mile | 11.2 sec / 195.6 km/h | |
| Top Speed | 240.2 km/h | |
1988_fzr750_genesis.1212197190.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
