oil_change
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| oil_change [2008/05/22 16:35] – 70.244.154.128 | oil_change [2020/10/19 11:50] (current) – external edit 127.0.0.1 | ||
| Line 7: | Line 7: | ||
| * Oil Filter (see [[http:// | * Oil Filter (see [[http:// | ||
| * Scrap Cardboard / Aluminium Foil | * Scrap Cardboard / Aluminium Foil | ||
| + | **First start the engine and run until normal running temp is reached. Then begin. | ||
| **Begin the procedure: | **Begin the procedure: | ||
| - Remove your left fairing by using the 4mm Allen wrench. | - Remove your left fairing by using the 4mm Allen wrench. | ||
| - Remove fairing bracket that is near kickstand using a 10mm socket or open-ended wrench. | - Remove fairing bracket that is near kickstand using a 10mm socket or open-ended wrench. | ||
| - | - Use cardboard and place between the FZR's oil pan and header. Fold in " | + | - Use cardboard and place between the FZR's oil pan and header. Fold in " |
| - Place oil catch pan underneath oil drain plug. | - Place oil catch pan underneath oil drain plug. | ||
| - Remove oil drain plug with 17mm socket or open-ended wrench. When the plug is out oil should flow onto (aluminium-foiled) cardboard and into oil catch pan. | - Remove oil drain plug with 17mm socket or open-ended wrench. When the plug is out oil should flow onto (aluminium-foiled) cardboard and into oil catch pan. | ||
oil_change.1211492150.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
