oil_change
Assemble the following tools as needed:
- 4mm Allen Wrench
- 10mm and 17mm sockets w/ ratchet or open-ended wrenches
- Oil Catch Pan
- Oil Filter Wrench
- Oil (2.6 qts required)
- Oil Filter (see Oil Filter Cross Reference)
- Scrap Cardboard / Aluminium Foil
Begin the procedure:
- Remove your left fairing by using the 4mm Allen wrench.
- Remove fairing bracket that is near kickstand using a 10mm socket or open-ended wrench.
- Use cardboard and place between the FZR's oil pan and header. Fold in “V” shape at oil pan. Optional: Cover cardboard area with aluminium foil.
- Place oil catch pan underneath oil drain plug.
- Remove oil drain plug with 17mm socket or open-ended wrench. When the plug is out oil should flow onto (aluminium-foiled) cardboard and into oil catch pan.
- When oil has slowed draining, insert the oil drain plug into FZR's oil pan by hand.
- Move oil catch pan to front of bike and adjust “V” shaped (aluminium-foiled) cardboard to drain from underneath the oil filter and into the oil catch pan.
- Remove filter with wrench. Ensure that the oil is directing away from the headers and into the oil catch pan.
- Before installing new filter, use a small amount of new oil on filter seal. Install new oil filter - hand tighten.
- Remove “V” shaped (aluminium-foiled) cardboard and discard.
- You may remove the oil drain plug and allow the remaining oil to drain out.
- Install oil drain plug.
- Remove and discard cardboard.
- Remove oil catch pan from area. Remember to recycle.
- Remove oil filler cap and pour in new fluid. Yamaha recommends 2.6 quarts of oil with filter change. Keep a watchful eye on sight glass.
- Install fairing bracket and fairing.
- Turn over engine and let it run for a minute. Shut off engine, let it sit for a minute, then check oil sight glass and fill as necessary.
oil_change.1211492150.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
