Re: [Project thread] The Yellow FZR - 1990/1993 FZR1000
There are several Yamaha or Universal brake switches that could be made to work; what makes the proper part special is the bending of the wire hook so that it fits 'just so'. You do have to be careful about the connectors - your bike has two bullet terminals, while many others used a two-way connector. This switch on eBay should do nicely, with just a bit of persuading with a pair of needle-nose pliers.
- Kevadlilleke
- 100+ Posts
I was thinking more along the lines that "apparently they have stopped making/selling FZR brake switches, will a Thundercat/YZFR1/<insert any newer bike here> switch fit?"
2012
2013
2014
2012
"Yes", and - as far as I can tell - "No". Besides, the Emgo part is less than half the going rate for an OEM piece.
- Kevadlilleke
- 100+ Posts
Spring update - opening the '14 season:
- Rear shock readjusted to 1 click softer (7 clicks out)
- New tyres (Pirelli Angel GT 120/70ZR17 + 180/55ZR17)
- Replaced rear brake switch
- Received new intake rubbers (carb to airbox)
- Received new valve cover gasket
- Also, passed inspection
- Measure valve clearances, adjust
- Check the cam chain and tensioner
- Sync the carbs
- Rear brake master cylinder will need some serious cleanup or replacement
- Broke the exup cover and bolts
- There's not a single piece of plastic that doesn't need any repair
- There is still one loose connector, no idea what it's supposed to connect to
- Replace seat (or seat cover)
- Check clip-on slack
2012
2013
2014
2012
- Kevadlilleke
- 100+ Posts
2012
2013
2014
2012
- Kevadlilleke
- 100+ Posts
'14 season 1st month update:
- Synced the carbs
- Installed new intake rubbers (carb to airbox)
- Left vacuum hoses attached to the manifolds and plugged, to ease future sync (every 6000 km, according to manual)
- Fastened the throttle handle/switchbox, that had started rotating around the clipon
- Adjusted the headlights
- Tyres are good
- I need fairings
- Clover gear is excellent, everything underneath was dry when I got home
- "Anti-fog" coated visors suck, I need to get a pinlock visor
- I need to find the original rear mudguard (extension) from somewhere
2012
2013
2014
2012
- Kevadlilleke
- 100+ Posts
'14 season 2nd month update:
Clutch switch was a major win - now ALL the starting/ignition control items are in order! Also I win 5-10 seconds every time I mis-clutch at the traffic lights (less embarrasment time).
Also, got a record-low fuel consumption of 5.68 l/100km (41.4 mpg US/ 49.7 mpg UK). Nice.
Next in line:
- Installed new bulbs in the headlights
- One new bulb for the speedo
- Cleaned and fixed the clutch switch
- Got to the bottom of the clipon slack issue
- Got the pinlock visor
Next in line:
- Steering bearing inspection and re-lube
- Brake pad and caliper inspection and cleaning
- Valve clearance check
2012
2013
2014
2012
Pics?:)
Yamaha FZR 1000 1987 viewtopic.php?f=10&t=10936&p=93318#p93318
x Suzuki GSXR 600 2008
- Kevadlilleke
- 100+ Posts
Pics of what?
2012
2013
2014
2012
