Your mom sounds.......zero9243 wrote: I was gonna say : Sounds perfect.
Zoot Scoot Riot Project - Codename: Scopper (Updated 7/18)
Re: Zoot Scoot Riot Project - Codename: Scopper
Do YOU Scopper?
Kiss your mother with that mouth? Why aren't you on instant messenger!?thatkid wrote:Your mom sounds.......zero9243 wrote: I was gonna say : Sounds perfect.
Also, how about a pic of the clean basement! Might as well show them we got SOMEthing done.
Upgrades:
zero9243 wrote:Kiss your mother with that mouth? Why aren't you on instant messenger!?thatkid wrote:Your mom sounds.......zero9243 wrote: I was gonna say : Sounds perfect.
I kiss YOUR mother....... Damnit, you make it so easy it just takes all the fun out of it.
I will get a pic of the cleanness a little later. I need to attempt to sleep first.
Do YOU Scopper?
- surgscrubfzr
i have a fzr 1000 speedo you can have. it has a plug cut off but i think it still works, i never actually used it. if you want it let me know.
- Level 8.0
OK i have a funny story.. So a young guy i ride with found out how old i was... He was like "damn, your old enough to be my dad.." I said, "I might be..?What's your mom look like?? " I'm huntin' Milf's boyz ..thatkid wrote:Your mom sounds.......zero9243 wrote: I was gonna say : Sounds perfect.
NO FZR
05 Yamaha R1
03 Harley Fatboy
what's next?
05 Yamaha R1
03 Harley Fatboy
what's next?
Looks like the MILF MAN has arrived.
He leaves all the mom's with big white creamy mustaches.
Alright another update. I was down there for a good 8-9 hours. It doesn't look like I was down there that long but some of this crap takes a lot longer when you don't have the right tools. Anyway, Here's how the basement was left after Zero helped me clean up my work station.
I did move a bunch of moto parts from the garage to the basement after we had it very clean so that's what the boxes are.
All my metal stock organized.
I built a wheel chock for the front wheel so it doesn't try to tip over again.
From there it was a lot of cleaning and painting today. I think I have almost everything cleaned and painted so that when I start to assemble I won't have to do anything but that.
Then I fixed the exhaust a little more. I'm hoping that the textured powder coat that Zero is going to get done for me ( ) will hide some of the blemishes.
I got the head tube welded on like nobody's business. Cutting the tube and square tube in half with an angle grinder took a very long time but the results were worth it.
This picture is showing where the shock lines up in comparison with where the frame attaches.
And a finishing shot of the profile as she sits right now.
That's all I got done today. I spent a good amount of time fixing some blemishes in the main tube that were there when I bought the tube. I got a discount on it but looking back I should have just driven to the supplier and bought a new piece. A lot less headaches but not much I can do now.
Oh! I'd also like to thank Yam for grip money and the Finch for a gas cap and spout. And I think he beat me to it but thanks also go out to Zero for a battery, turn signals, and time. (and powdercoating ) I may finish under budget after all!
Soon I will place the final order with DennisKirk and see how much is left in the budget for powdercoating the frame. I hope there will be enough.
Do YOU Scopper?
How are you going to attach the shock to the frame? Seems offset and at a distance. Nice job on everything, looks like it was way more time consuming than those pictures show.
Yeah that thing is gonna look sick powdercoated!! Nice work dude, I like the addition to the frame that you welded on. Looks real clean. And that wheel chalk... genius!!
Upgrades:
nice!
SOLD
SOLD
Yeah, the shock is about 4 inches to the left of the frame. I'm still working on an idea that would be presentable yet functional. Since I have other things I can be doing I'm not worrying about that one just yet. I still need to find out if that por-15 can take the heat of powder coating or if I have to do it after I get the frame coated. Cause if I can do it before it will make like much easier.YAM93 wrote:How are you going to attach the shock to the frame? Seems offset and at a distance. Nice job on everything, looks like it was way more time consuming than those pictures show.
Do YOU Scopper?
*chanting* rolling chassis! rolling chassis! Rolling Chassis! ROLLING CHASSIS!!! CMON LET'S SEE IT!
Upgrades:
maybe wednesday. If I had help it would go faster but book someone had to go to the dells. Sent again from the free iPod touch. I would never pay 300 for one of these but it sure it damn cool.zero9243 wrote:*chanting* rolling chassis! rolling chassis! Rolling Chassis! ROLLING CHASSIS!!! CMON LET'S SEE IT!
Do YOU Scopper?
i don't think por will stand the heat , they do have high temp por but only in shades of silver for painting exhaust manifolds and stuff . what are you gonna use for a seat ? i got a real nice sprung chopper solo seat that was too wide for my triumph that i'd let go if you're interested , it's been sitting here wrapped up waiting for something cool to go on but i don't do a whole lot of chopper stuff anymore .
Got busted plastics ??? go here : viewtopic.php?f=8&t=209
I have no idea what I'm doing for a seat yet. A sprung seat could look pretty damn cool. By let go do you mean donated or cheap? Cause any other options are pretty much out of the price range on this build. I really want to stick within my $400 budget. As of now I think it can be done, but it's a no frills sort of budget that is left.Dr Rockso wrote:i don't think por will stand the heat , they do have high temp por but only in shades of silver for painting exhaust manifolds and stuff . what are you gonna use for a seat ? i got a real nice sprung chopper solo seat that was too wide for my triumph that i'd let go if you're interested , it's been sitting here wrapped up waiting for something cool to go on but i don't do a whole lot of chopper stuff anymore .
Do YOU Scopper?
