How can i deep clean my chain?
desmarat
Level 1.5
Level 1.5
Post by desmarat »
I have the chain pulled off right now and was wondering if there was a way to give it a extra deep clean? I have herd of dips and boiling, any ideas of advice would be appreciated? Thank you!
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
Redoliander
100+ Posts
100+ Posts
Post by Redoliander »
Put it in some kerosene and use a grunge brush or a toothbrush to clean all the gunk off.
desmarat
Level 1.5
Level 1.5
Re: How can i deep clean my chain?
Post by desmarat »
Okay thanks, should i let it soak in the kerosene for any time before scrubbing? Should i wash it off after with anything or just dry and wax?
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
Redoliander
100+ Posts
100+ Posts
You can let it soak. After you clean it you can dry it with a rag then trow wax on it or wash it and let it dry then wax it. It's usually said its best to warm the chain then wax it. Not sure how important it is though. I use duponts Teflon chain wax. Works good with minimal fling off.
pefrey
Level 5.5
Level 5.5
Post by pefrey »
Did you mention boiling? Holy cow that sounds bad.
As mentioned, soak in kerosens an brush off the gunk.
Kenny two guns
Post by Kenny two guns »
Soak in kerosene overnight. Let it drip dry for a half hour after scrubbing, the kerosene dries/evaporates quickly. Also Kerosene is used because it does not hurt the O-rings & X-rings in the chain. Unlike introducing boiling water or wd-40 to the chain..
1995 Yamaha FZR600
1992 Kawasaki EX500
desmarat
Level 1.5
Level 1.5
Post by desmarat »
Awesome, thanks guys! Ill go get a can of kerosene and get to it.
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
KaspenOne
100+ Posts
100+ Posts
Post by KaspenOne »
i heard pinesol and a lil water works great and dont damage the o rings, just make sure to dry it off before spraying your lube on it ;)
1996 Yamaha Fzr 600
Racetech Front suspension
KaspenOne
100+ Posts
100+ Posts
Post by KaspenOne »
1996 Yamaha Fzr 600
willandrip
Level 7.0
Level 7.0
Post by willandrip »
desmarat wrote:I have the chain pulled off right now and was wondering if there was a way to give it a extra deep clean? I have herd of dips and boiling, any ideas of advice would be appreciated? Thank you!
Gosh,how times have moved on.
Linklyfe or Castrol heated chain grease.
Sadly a long forgotten method, used before O ring chains or aerosol lubricants were invented.
Bet Y.G. has experience of this method. :thumbsup:
desmarat
Level 1.5
Level 1.5
Post by desmarat »
pinesol huh? I think i will stick with kerosene. Byt thanks for the reply, another idea indeed. Just looks like the kerosene way is the more commonly acceptable way to go about it. And i have never herd of heated chain greese, does it work better than regular spray wax? last any longer or give better lubrication or durability?
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
