New Paint for my 1990 400
FZR400 Forum
JustinLonghorn
Post by JustinLonghorn »
Base coat layed:
Black over yellow:
Applying decals:
Just shot the clear last night:
"Art is never finished, it is only abandoned."
1990 Yamha FZR400
1975 Honda 400F
1975 Yamaha DT250
Frederick, MD
Brown Stain
Post by Brown Stain »
Sweet! Love the yellow and black.
kilika2
Re: New Paint for my 1990 400
Post by kilika2 »
I am liking what I am seeing. Keep it up.
1995 FZR600 Sold :-(
2006 R1 Sold :-\
2009 Buell 1125R :-)
olie05
Level 2.0
Level 2.0
Post by olie05 »
I like the chain blocks scheme a lot. Looks good.
kilika2
Post by kilika2 »
Did you have any problems with bugs and dirt? I had to paint a car outside one time and I was on the third coat of paint. And of course a moth lands on it. However the funny part was we kind of turned it into a tattoo if you will. The moth flew off but left a perfect impression. So I took some black and outlined and shaded it a little. Was pretty neat.
2006 R1 Sold :-\
JustinLonghorn
I definitely have had a couple of gnats land in the paint. Wetsanding makes them almost unnoticable, ha, but I know they are there.
1990 Yamha FZR400
1975 Honda 400F
1975 Yamaha DT250
Frederick, MD
kilika2
Post by kilika2 »
I've seen something have always wanted to try. You put on to coats and then on the third when its still wet you take wrinkled up paper or something and press it against the paint. And then clear 8-9 times. The other alternative is doing what lambo does and wet sand in between coats and clear coats. That would be a lot of work. Worth it though.
2006 R1 Sold :-\
nicrod
Post by nicrod »
at first I was like ....oh..
but then I was like..
OH!!:D
that turned out well dude, got more pics of the bike all assembled?
riturbo
Post by riturbo »
Lookin Good :cheers:
1990 fzr 400
1985 gpz 750 turbo
1981 gpz 550
1983 gpz 550
1990 zx 7
Gizzard1533
Level 2.0
Level 2.0
Re: Re: New Paint for my 1990 400
Post by Gizzard1533 »
kilika2 wrote:I've seen something have always wanted to try. You put on to coats and then on the third when its still wet you take wrinkled up paper or something and press it against the paint. And then clear 8-9 times. The other alternative is doing what lambo does and wet sand in between coats and clear coats. That would be a lot of work. Worth it though.
Wet sanding between coats helps to dampen the orange peels affect that occurs, it provides a smoother surface for your next layer of paint. A quide coat is also very useful, you spray a couple of layers of paint and then sand back to original, this then leaves the paint in the lower areas of the bodywork showing up which bits need attention.
Very nice job by the way, cant wait to get stuck into mine :thumbsup:
Sent from my GT-I9100 using Tapatalk 2
JustinLonghorn
I did indeed wet sand between each step (primer/base/secondary). I will also wetsand from 600-2000 and then buff when the clear has cured enough.
One word of caution when it comes to wetsanding. Between steps, use a 600 grit paper. If finer grit is used, the surface can be to smooth, and the next coat will not adhere properly.
As soon as the bits are cut/buffed, I will re-assemble the little 400 and get some proper pictures taken.
I appreciate all of the kind words, fellas.
1990 Yamha FZR400
1975 Honda 400F
1975 Yamaha DT250
Frederick, MD
gsxridiot
Post by gsxridiot »
SPEED BLOCKS!
my favorite design
very nice!
2012gsxr750
07gsxr750 track(gone)
91gsxr1100
1989 fzr400
400/600 in the making
JustinLonghorn
Cutting and buffing is for the birds. However, there is something satisfying about this:
And here is it starting to look like an actual motorcycle:
1990 Yamha FZR400
1975 Honda 400F
1975 Yamaha DT250
Frederick, MD
JustinLonghorn
Took it and my other baby 4 out for a ride yesterday.
1990 Yamha FZR400
1975 Honda 400F
1975 Yamaha DT250
Frederick, MD
JustinLonghorn
1990 Yamha FZR400
1975 Honda 400F
1975 Yamaha DT250
Frederick, MD
