Jerky low speeds *FIX = Cush Drive Bushings*
pnbell
100+ Posts
100+ Posts
Post by pnbell »
Hey all,
I new to this Forum / FZRs in general. So first off: Hi, I have a Black 98' FZR600 with about 16k miles.
OK, I have been riding this bike for a week. Great Bike, easy to handle, nice throttle and brakes; BUT every time i would get ON or OFF the Throttle -the bike would like Jerk, Buck, and/or Lurch; In General any changes in throttle (way more obvious at low speeds) were not smooth. Going low speeds in 1st or 2nd gear were impossible without constantly feathering the clutch... Really annoying and uncomfortable.
Here is the solution that made my bike 100% better:
First: i rev'ed the engine and noticed it was very smooth with no hesitations...
Second: with the bike Off, and Parked i grabbed the Rear Sprocket and noticed i could twist it back and forth pretty easily about a 1cm or 1/4in
Third: Ordered New Cush Drive Bushings (about $50)
Fourth: Installed the New Cush Drive Bushings
Fifth: Check and Tightened the chain a little (as a loose chain would also cause a similar issue)
Sixth: Drove the Bike and smiled because i could now drive at low speeds (under 20mph) in 1st and 2nd gear with no Bucking, Jerking, or Lurching! And without feathering the clutch constantly...
Long Story Short: If your bike is really Jerky at low speeds check your rear sprocket for movement; with the New Bushings it does not move at all by hand.
my2cents
-Pete
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
old_school
Level 8.0
Level 8.0
Re: Jerky low speeds *FIX = Cush Drive Bushings*
Post by old_school »
Welcome and thanks for the tip.. I was thinking your chain was loose
NO FZR :(
05 Yamaha R1
03 Harley Fatboy
what's next?
cowboi
Level 2.0
Level 2.0
Post by cowboi »
Great info. Welcome to the funhouse.
sent from a portable leash
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
97fzrnoob
Post by 97fzrnoob »
Thanks for the tip, I'll have to try that. I've had same issue for a month now and been at a loss trying to figure it out. I did notice when i put new sprockets and chain on that I had some play in the cush bushings.
pnbell
100+ Posts
100+ Posts
Post by pnbell »
old_school wrote:Welcome and thanks for the tip.. I was thinking your chain was loose
Yea well the Chain was also pretty loose... But the Cush Drive was unbelievably worn; like the rear sprocket just fell out of the wheel.
and as an update i can now drive smoothly in 2nd gear at low speeds; so nice.
Thanks for the welcomes, i'll be tinkering a lot with this bike and so i'll likely be pretty active on this forum.
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
kilika2
Post by kilika2 »
I'm assuming this is also a good start if you are having problems with your chain being tighter in some spots than others.
1995 FZR600 Sold :-(
2006 R1 Sold :-\
2009 Buell 1125R :-)
buzzawak
Level 2.0
Level 2.0
Post by buzzawak »
kilika2 wrote:I'm assuming this is also a good start if you are having problems with your chain being tighter in some spots than others.
Sound more like you just need a new chain dude.
pnbell
100+ Posts
100+ Posts
Post by pnbell »
yup. if your chain is tighter in some spots it's stretched and is about time to replace... About to replace mine in the next week or two... Couple bad links is making the chain loose and tight, i can hear the chain clicking while pushing or driving the bike around...
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
kilika2
Post by kilika2 »
Yeah the bad thing is this chain an sprocket set has less than 8000 miles on it. And I bought it after my tires. Still havent replaced them yet Haha. However I am running 14/49 so I have heard the large difference in sizes can make a chain wear fast.
2006 R1 Sold :-\
pnbell
100+ Posts
100+ Posts
Post by pnbell »
Yea, i was thinking about doing the Quick Accel 520 Conversion; but as i just got the bike, i figure i'll save that upgrade til i am getting bored and want to make things exciting again.. haha!
What Brand/Type of Chain did you go with? I've heard cheaper brands tend to stretch and wear faster. Also do you lube it often? Just curious as i'd like to avoid replacing my chain often...
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
kilika2
Post by kilika2 »
I got it from sum of all parts.com. I wouldn't go there though as I've been reading on eBay there are some very unhappy customers. I think the economy got to them. However DID chain and vortex sprockets. Yes I lube the chain about ever 500 miles or if I know it will sit for a bit. I highly recommend the 520 conversion. It's a lot of fun. Another problem I can think of that probably caused my uneven wear. When I first put the chain on I dove for about a thousand miles before I checks te tension by then it was pretty loose and I probably didn't help things with that.
2006 R1 Sold :-\
