Oil line damage
Siheinz
Oil line damage
Post by Siheinz »
While looking at my broken exhaust studs at the weekend I noticed the external oil line that runs from the oil filter housing to the head
has been crushed to half its original diameter! looks like plier marks?
Would this have caused the head to suffer oil starvation? and would it be easier to source a replacment engine to be on the safe side?
Cheers Si
1990 FZR 600 UK Spec
crowe
Re: Oil line damage
Post by crowe »
for the sake of a bit of rubber hosing i'd replace it. better that than running the risk of oil starvation. replacement engine is an option but quite drastic. if it just to rob bits of to keep yours going or to break both and build one good one out of two then fair play but thats alot of work to do yourself especialy if you knowledge of engines is limited.
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
Siheinz
Re: Oil line damage
Post by Siheinz »
very good at building vw flat 4's no help with this engine
the pipe in question is metal looks the same width as brake line on a car, will pop a picture on latter
Gizzard1533
Level 2.0
Level 2.0
Re: Oil line damage
Post by Gizzard1533 »
You can buy replacement hoses, i may still have a set from my old engine. I'll have a look around but im sure you could get them from ebay or the like.
pefrey
Level 5.5
Level 5.5
Re: Oil line damage
Post by pefrey »
I know the line you are talking about, it's not a hose as others are suggesting. It'd reaplace the line. You should be able to find one from somebody that is parting and engine.
Nik
100+ Posts
100+ Posts
Re: Oil line damage
Post by Nik »
Siheinz wrote:While looking at my broken exhaust studs at the weekend I noticed the external oil line that runs from the oil filter housing to the head
Cheers Si
S,
replace it NOW do not ask just do it, a starved head breaks and is EXPENSIVE for the sake of the price for an piece of oil line Check out THATKID (forum member) he must have it in stock
W.F O
Nik H.
There are two kinds of posts on Forums.
1. This is what I have done...
2. This is what I think...
Be aware of the difference!
Siheinz
Re: Oil line damage
Post by Siheinz »
thatkid
Re: Oil line damage
Post by thatkid »
If you can't find one locally I can ship you one but shipping across the pond will be the expensive part.
Do YOU Scopper?
Siheinz
Re: Oil line damage
Post by Siheinz »
Thanks will let you know, hope not to much damage has been done to the head!
Re: Oil line damage
S,
not only has that been kinked partially closed but there appears to be burn damage to the outer cover where it has touched the head.
There are hydraulic pipe guys who will make that pipe up for you for not great loads of money, I used a fork lift truck hydraulic specialist (I took a quick look for his card but cannot spot it ) I fished him from the Yellow pages if I remember correctly.
HTH
Siheinz
Re: Oil line damage
Post by Siheinz »
Thanks YG will have a look on yell.com lots of industrial units near me.
Re: Oil line damage
Siheinz wrote:Thanks YG will have a look on yell.com lots of industrial units near me.
S,
glad to help out , let us know how you get on. A good reference for our fellow Brits if we can point them at someone we have used, now where the H*** is that card. :whistle
reelrazor
Wrench
Wrench
Re: Oil line damage
Post by reelrazor »
Worst comes to worst, a piece of metric brake line and two compression fittings will run you about $3.
That banjo fitting is about a $4 item.
taggy
Level 1.5
Level 1.5
Re: Oil line damage
Post by taggy »
ive got one in much better condition than that! if i can find t after the house move! pm me if you still need it!
Fzr400 3tj x2
'94 cbr 900rr
Gizzard1533
Level 2.0
Level 2.0
Re: Oil line damage
I've found my one. cost of postage and its yours? pm if interested? can post asap.
