Spin on oil filter mod but with an oil cooler?
Clanky
100+ Posts
100+ Posts
Post by Clanky »
My 89 FZR has a factory fitted oil cooler. Can I still do the adaptor plate swap to use the later spin on filters or are the internal water/oil ways different in some way with the oil cooler set up?
FZRDave91
Re: Spin on oil filter mod but with an oil cooler?
Post by FZRDave91 »
Thats an interesting question. From the looks of it I dont see why it wouldn't, but don't consider this advice.
Hopefully someone else will chime in who has run into this before.
1991 FZR600 w/ YZF VR Upgrade, Twin Headlight conversion
1981 XS400 Cafe build.
Can't ya tell I like Yamahas?
DonTZ125
Moderator
Post by DonTZ125 »
Unless I'm mistaken (it happens. Occasionally ... :mrgreen: ) the 'nose' on the 'internal' filter mount cases stands 3mm proud compared to the plate mount for the spin-on cases. I would be surprised if this cooler mount did not have a similar profile. Adding the adaptor plate requires either machining a relief groove in the plate or machining down the nose. Not hard, but not something to do with hand tools.
Clanky
100+ Posts
100+ Posts
Post by Clanky »
Thanks for the confirmation, Don.
I was uncertain if the older style filters had any internal differences that prevented the normal mod. I'll get sourcing some parts.
Regards
Nigel
Nik
100+ Posts
100+ Posts
Post by Nik »
Clanky wrote:Thanks for the confirmation, Don.
Regards
Nigel
Nigel,
I had this conversation with Y-Geo when he was here I seem to remember he said there was an aftermarket kit made for doing just that with some kind of adapter plate. I hope he chimes in at this point as I could have that the wrong way round.
W.F O
Nik H.
There are two kinds of posts on Forums.
1. This is what I have done...
2. This is what I think...
Be aware of the difference!
Clanky
100+ Posts
100+ Posts
Post by Clanky »
Hi Nik,
Thanks for mentioning the kit. There were a couple of posts I found that listed the parts needed for the swap and I do remember reading about a kit someone had put together but I don't know if that's still available.
The part numbers for anyone interested are:
90401-20145-00 BOLT, UNION
3TJ-13461-00-00 PLATE, ADAPTOR (Like done Don said in his post above this will need some machining to fit)
93210-87723-00 O-RING
dru86
Level 1.5
Level 1.5
Post by dru86 »
I actually did this swap with my fzr600. There's a hollow bolt that goes through the oil cooler adaptor that needs 3mm removed (part 7 on the first image). Apart from that all you need is part 1, 2, 3 & obviously 4 on the second image.
Clanky
100+ Posts
100+ Posts
Post by Clanky »
Hi Dru,
Nice to know it worked for you. I will get round to this swap eventually but need to source the parts, just waiting to get them at the right price!
