Unable to turn rear wheel when the bike is on lifts?
- Crying Freeman
Hi All,
I was going to lube my chain and put my bike on lifts via the rear swing arm.
For some reason, I'm unable to fully turn the rear wheel. The wheel would only turn for a few inches only and then it seems to lock. When turning the wheel the opposite direction, it would do the same.
Once the bike is off the lifts, I can push and move the bike without problems.
Does anybody know why?
Thanks for your input...
1998 Yamaha FZR 600
- trifgeorge
- Level 2.0
Re: Unable to turn rear wheel when the bike is on lifts?
You could have a warped rear brake disc, or have stuck links in the final transmision chain, or a really bad rear wheel bearing.
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
R6 pilot seat
KOSO mirrors
H1 HID
- Crying Freeman
But I can push the bike back and forth without problems but when the rear is on lifts, I can only turn only about three inches back and forth...It doesnt make sense...trifgeorge wrote:You could have a warped rear brake disc, or have stuck links in the final transmision chain, or a really bad rear wheel bearing.
1998 Yamaha FZR 600
I had this, found the paddock stand catching on the sprocket mount.
Turn your hooks the other way round.
89 FZR400 project bike... apologies in advance for anything dumb i say or ask!
- Crying Freeman
I'm not sure what you mean...the stand is directly under the rear swing arm and not near the rear sprocket. I can move the wheel back and forth about 3 inches only. It seems lock something is definitely locking it from rotating the wheels more than 3 inches in either direction...slaveunit wrote:I had this, found the paddock stand catching on the sprocket mount.
I'm open to any theories...
1998 Yamaha FZR 600
Crying Freeman wrote:I'm not sure what you mean...the stand is directly under the rear swing arm and not near the rear sprocket. I can move the wheel back and forth about 3 inches only. It seems lock something is definitely locking it from rotating the wheels more than 3 inches in either direction...slaveunit wrote:I had this, found the paddock stand catching on the sprocket mount.
Chain/sprocket issues. Chain too loose? Sprockets worn?
- Crying Freeman
When the bike is off the rear stand, I can move it back and forth and ride it without problems. It's so weird b/c its like the rear wheel is locked once its off the ground.
1998 Yamaha FZR 600
- kilika2
- 1000+ Posts
I'm going to throw this out there but you dont have it in gear do you? And when you are pushing it off the stand holding in the clutch. Not trying to be a jerk sometimes its just a doh moment. Also I've put mine on the stands and started to roll it and hit the nuts that hold the rear sprocket on even though I had the stand what I thought was way forward.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
I'm with the crowd saying the rungs on the stand are hitting the nuts around your rear sprocket. Look where the rung is on your swingarm when the bike is lifted, turn the rim and see if your rung impacts the sprocket nuts. If it's impacting there than move it forward or back further on the swingarm to miss the nuts.
- Crying Freeman
I nominate myself (and probably others here as well) to receive the "DUMB ASS" of the month award to myself...
It was the pads that are used to lift the swing arm was hitting the sprocket nuts...
Thanks to all who responded...
1998 Yamaha FZR 600
- kilika2
- 1000+ Posts
We've all been there.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
- Crying Freeman
You were right...thanks!slaveunit wrote:I had this, found the paddock stand catching on the sprocket mount.
1998 Yamaha FZR 600
- Crying Freeman
You were also right...thanks!_Will_ wrote:I'm with the crowd saying the rungs on the stand are hitting the nuts around your rear sprocket. Look where the rung is on your swingarm when the bike is lifted, turn the rim and see if your rung impacts the sprocket nuts. If it's impacting there than move it forward or back further on the swingarm to miss the nuts.
1998 Yamaha FZR 600
It's through experience that we knew, it happens
I'm a winner!Crying Freeman wrote:You were right...thanks!slaveunit wrote:I had this, found the paddock stand catching on the sprocket mount.
