Fuel pump testing/rebuild
- MaParkerColo
Hey all,
The bike was down for a time with a fried VR. I recently got every thing together, replaced the VR with one from and R1 and pulled and dipped/cleaned the carbs. I can't seem to get it to stay running, acts like it isn't getting fuel. I pulled the fuel line and although I hear a "Click" from a relay no gas gets pumped. Hmm sounds like a bad pump? I tried jumping 12V directly to the pump's wires. Nothing. I put a voltmeter on the wires from the relay to the pump and see ~12V for a few seconds when I turn the key on just like I'm supposed to.
What is the next step? Can I pull the pump apart and rebuild anything or do I just need to find a new one?
Anyone have a fuel pump laying around?
Thanks,
Mark in Colorado
Thanks,
Mark in Colorado
Mark Parker
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
Re: Fuel pump testing/rebuild
Hi Mark. Try giving it a gentle tap with something like the handle of a screw driver or ratchet. My bike sat for a while as well with all the gas drained from the pump. When assembled it would not pump, I just felt a dull thud from the pump when I turned the key. A couple taps and it started pumping again. I figured it was stuck due to any residual gas that may have dried internally.
2005 FJR1300- Daily ride
1990 FZR600- Stock
1984 KR RZ350- Restored
1990 FZR600- Stock
- MaParkerColo
Thanks lewdog, tried that an no luck. It appears to be dead. I pulled it and put voltage across, checked the ground etc. I think I need to source a new pump. Anyone know of sources for inexpensive pumps? I would prefer new to used, but will probably need to end up going used.
Mark Parker
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
- racerd14666
- 100+ Posts
some times you can flush the pump out with a good turkey baster or something els you can apply pressure and vacuum with
Yamaha Certified Technician
- MaParkerColo
Fuel pump questions
Thanks racerd, but it appears to be an electrical rather than a mechanical issue.
Does anyone know if the pumps from the YZFs are the same/compatible replacements??? There is one available locally and it looks to be about the same, but I don't have any information about how much pressure they run etc.
Mark Parker
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
- sleepyz0mby
yes the yzf 600/thundercat will work. not sure about the r6. the yzf will fit right in the mount too. i think the yzf is a lil big... but it will work.
good luck
good luck
- racerd14666
- 100+ Posts
if the pump is off a carb'd yzf it will work cus they all run the same 0.95 psi
- MaParkerColo
racerd14666 wrote:if the pump is off a carb'd yzf it will work cus they all run the same 0.95 psi
That's what I was hoping to hear. Thanks for the info. Now if I can get them to a decent price I'll be good to go!
Mark Parker
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
1993 Yamaha FZR 600
1981 Suzuki GS450
Colorado
MPC,
PM THATKID he has lots of FZR bits and he does decent prices.
thatkid
I couldn't agree more.yamaha_george wrote:MPC,
The overcharging VR more than likely took out the fuel pumps internal windings, rendering it beyond repair.
